Browse Forums Kitchen Appliances 1 Apr 10, 2018 3:05 pm Has anyone done this? Was it worthwhile? I don't know where to start ? Who does this ? appliance repairer, specialist sealing company, ??? All suggestions welcome. Thx everyboday Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Replacing fridge seals 2Apr 10, 2018 8:27 pm Certainly worth it if your seals a worn or cracked. You can easily do it yourself if you can use a screwdriver. Here are some options that may provide you the seals by online order or can come and service in your area if you prefer that: http://www.sealafridge.com.au http://www.bunneys.com.au/appliance-services-sydney/fridge-repair/ https://www.allfridgeseal.com.au http://www.appliancerepairssutherlandshire.com.au I’m restoring all my 40yr old windows and I want to install seals around the casements. I’ve sanded back and oiled the frames with sikkens. My plan is to box up inside… 0 6510 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7529 2 8356 |
