Browse Forums Kitchen Appliances 1 Aug 29, 2017 7:49 pm Hi, We have selections coming up soon, so need to make a decision on our ovens. I do not want a 900 oven as I don't want that much oven in one and would prefer to have 2 so I have the option to cook at different temperatures or just to heat up a small oven when I only have something small to heat up. The options I am looking at are 2x 600 Smeg ovens which are 79L capacity or Smeg double oven which has a 79 and a 41L capacity. We have the option in our kitchen to either do a wall mount or undermount oven What would you prefer and why? TIA Re: Double oven or two ovens 2Sep 01, 2017 8:15 pm Think both options is goid Will depend on what you are comfortable with. Double iven might be easier to install but 2 separate ones might be easier to fix up or replace in future I only have one oven and then one of those thats on the bench (see through glass) that can bake/roast/cook Depending what i want to make between the two its doing great Re: Double oven or two ovens 4Sep 02, 2017 10:01 am we currently have a freestanding and i don't like bending over to get stuff in and out - so sounds like wall mount would be the better option. good idea on setting it up to have one that is more for grilling - thanks Re: Double oven or two ovens 5Sep 02, 2017 12:31 pm I went from a freestanding 900mm to 2 x combi steam and 1 x pyro wall mount. I've never looked back it so lovely not having to bend down HS practically sit on the floor to peer into the oven <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Double oven or two ovens 6Sep 02, 2017 2:03 pm ooh - i'd love a steam oven and a pyro oven - think might be out of our price range though. Re: Double oven or two ovens 8Jun 27, 2018 3:03 pm We have had both. I changed a single oven that was about to burn the house down to a full double oven which was equal size top and bottom. Only disadvantage I found was that the bottom oven had less cooking options than the top oven, something to check out if you go down this path. Recently I have changed this oven to a Siemens pyro oven and a 45L combi steam cooktop with a warmer drawer underneath it. This fits inside the same footprint as the old double oven. This method has given us a lot more flexibility as we have a small oven for the two of us, and everything for when the tribe is around. Hope this helps. Regards Graham and Kathy Owners of 2.5 acres of Paradise.......now working towards the house! Re: Double oven or two ovens 12Jun 15, 2020 9:34 pm One benefit if you have the kitchen space of having two is they could be side by side and have both at the perfect height, if you have a double then you are somewhat comprimising on the perfect height for one or both of them. one thing I'd love is a pair of dishwashers in the pantry, running two loads a day gets old Slooowwwwly getting a Manhatten 35 in Middleton Grange Hi, We're building a double-storey in Perth and I'm undecided with the kitchen sink situation. I'm set on having the main sink with dishwasher in the scullery - and… 0 20912 2 2983 The price you're seeing for a high-spec 2-storey home in Perth sounds steep, but unfortunately, it's kind of the norm these… 8 7855 |
