Browse Forums Kitchen Appliances 1 Jun 13, 2017 5:41 pm Hi all, I currently purchase a range hood and installed in my kitchen, but the problem is I can't find the pipe hole up to the celling, I check the celling it does have a metal part attached with pipe toward outside, in this case should I drill a hole under that meta part so I can install the pipe? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Range hood question 3Aug 16, 2017 8:27 am Have you removed the rangehood to see if you can see any ducting and where it goes? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9963 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6157 1 13128 |
