Browse Forums Kitchen Appliances 1 Dec 28, 2016 8:33 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ (http://imgur.com/a/YYSHy) I'm installing a dishwasher. Power point already exists; cabinet already sorted. I just need to get the right fixing to split the cold flow into two. What are the parts I need? Any advice on how to do it? Trying to save $300, which a plumber has quoted me... Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12663 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2603 I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 2700 |
