Browse Forums Kitchen Appliances 1 Feb 10, 2016 6:39 pm Okay, after dealing with a cabinet hole that was too small for a water inlet / heater hose now I'm stuck as to how to connect the waste water outlet to the kitchen drain. The place is about five years old (moved in a few weeks ago) and seemingly none of the previous occupants installed a dishwasher. There are two pipes/outlets sticking out (below) which look like they're permanently sealed. Picture of the set up https://flic.kr/p/D2vW8y Close up of the two outlets https://flic.kr/p/D2vXnY Close up of the inside of one of the outlets (same for both) https://flic.kr/p/D2vX5d Question 1, are these outlets for connecting to a dishwasher outlet? Question 2, which one do I use? Question 3, and how exactly do I open up the outlet? i.e. do I cut the cuff off or do I punch a hole through?? Thank you in advance! Re: Help!! How do I connect the dishwasher outlet to the dra 2Feb 10, 2016 7:41 pm Hi JH, Your correct, they are both used for connecting the dishwasher waste. It doesnt matter which one you use, just drill the out the thin cover of plastic that is sealing them shut and then connect your waste hose onto it with a worm drive clamp. DONE! My build with FHBD viewtopic.php?f=31&t=78344 I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 2747 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4613 |
