Browse Forums Kitchen Appliances 1 Feb 14, 2014 9:36 pm Is bench top lighting expensive to instal and maintain and what other matters need to be considered? Our current down lights are effective, but every new kitchen seems to have some form of extra lighting,mostly to show off the bench tops and splashbacks. Re: Bench top lighting 2Apr 06, 2014 10:41 am Hi, we are putting strip lighting in under our overhead cupboards, to highlight our backsplash,they are simple to install, and not to pricey wasnt going to until we saw how nice it looks other than that we have down lights in our kitchen, l don't personally like hanging lights over the bench top, dust collectors over your food preparation area Re: Bench top lighting 4Jun 30, 2014 6:51 am It isn't hard at all we did it too with some LED strip lights - it makes such a huge difference we'll definitely be adding it to our build when we get overhead cupboards eventually Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31229 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3765 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28761 |
