Browse Forums Kitchen Appliances 1 Nov 19, 2013 9:10 pm We've just bought one of these and thought we'd share it in case anyone is on the look-out for one. http://www.harveynorman.com.au/kitchen/kitchen-appliances/fridges/westinghouse-762l-french-door-fridge-with-ice-and-water-dispenser.html With $200 cashback from Westinghouse and a $270 EFTPOS card from Harvey Norman. Plus free local delivery. It's a bit of a bargain. Re: Mighty cheap French Door fridge 2Nov 20, 2013 6:48 pm That is a great price. Shame it's too deep for me Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Mighty cheap French Door fridge 3Nov 21, 2013 3:29 pm Good price, but reading the reviews, there seems to be a common fault with water leaks. I was very tempted (and still am) but don't want to take the risk of leaking due to my timber floorboards. I'm assuming you haven't used yours yet oncewerefurriers? Re: Mighty cheap French Door fridge 4Nov 21, 2013 10:27 pm JB1. No we've not even received it yet. I'm wary of putting too much faith in reviews. Review sites tend to be quite polarising. 10 reviews from how many units sold? Maybe it will turn out to be a dog, it'll go back if it is. Looking at those reviews, at least two of those leaks look like they were caused by the purchaser connecting it up. And another one talks about the internal filter leaking? It's got an in-line filter. Re: Mighty cheap French Door fridge 5Nov 23, 2013 5:03 am I'm also slightly skeptical, however Most products at least have some level of good feedback, but it looks like the water leak is common fault and even the positive reviewers had issues with the fridge. If it was an user installation error, water connections leak almost immediately. I wouldn't have an issue with this fault as there is always warranty and the option to return it, if not for the fact I have solid overlay timber floorboards. Re: Mighty cheap French Door fridge 6Nov 23, 2013 12:05 pm Yep. Risking $1000s in flooring to save a few $100? In your situation I wouldn't risk it. We're going for sealed, polished porcelain so it's not so much of an issue. I was alluding to the fact that (reading between the lines) a couple of those people said they had pulled the fridge out to make it work/find the leak. I inferred that they had a water connection low, behind the fridge. It's not unusual to kink the hose/dislodge the filter seal. I've seen it with people doing the same with washing machines and they have heavy duty hoses not the thin, flexible ones fitted on fridges. We've got our tap at 1800m so we can observe any leaks from the hose easily. Re: Mighty cheap French Door fridge 7Dec 29, 2013 10:18 pm Saw one of these at a auction a few weeks back, had a couple of small marks on the doors, and went for $1200. Came with a 3 month manufacturer warranty too. Sorely tempted to buy one then, but thought by the time I get the new house built and it installed it would be well past the warranty should anything go wrong with it, and where we are renting doesn't have water access to hook it up to test it out. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Mighty cheap French Door fridge 8Dec 31, 2013 3:12 pm We're still waiting for delivery. Apparently there's no stock anywhere as Westinghouse are redesigning it. Hopefully fixing the leaking water dispenser. Re: Mighty cheap French Door fridge 9Dec 31, 2013 4:13 pm I picked up one of these for $1537 just before Christmas. Now retailing for $1495. http://www.appliancesonline.com.au/528l-samsung-3-door-fridge-srf527dsls/ It was free delivery for me ( I am in Sydney metro ). Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7512 1. Roof cleaning and paint - which colour do you recommend? I often see black/ dark grey in use these days but I would prefer… 0 8310 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6328 |
