Browse Forums Kitchen Appliances 1 May 15, 2013 10:04 pm Hi, my landlord has agreed to install a dishwasher into existing cupboards if I buy it. The space between the chosen cupboard is 57 cm, most dishwashers are 60cm. Is there any way to shift one of the cupboard's walls without a major renovate? Or am I stuck with an expensive, poorly performing slimline? Thanks. Re: Dishwasher install into existing cupboards 2May 28, 2013 3:50 pm You can try the Bosch built in compact dishwashers. While the outside width is 600mm, they're actually designed to be built into a standard 60cm cabinet frame (which usually has an internal width of about 560ish mm). But the height is shorter than standard dishwashers so you might need to put a drawer or something else for it to sit on. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ http://www.boschappliances.com.au/appli ... rce=browse Re: Dishwasher install into existing cupboards 3Sep 03, 2013 9:52 pm Sorry, can't solve the space issue, but also factor in installation costs.....? Is it already set up for a dishwasher, or not? Are you, or landlord, paying for a plumber? Does it need cold water tap + waste pipes etc.? Electrician ? (if no power point there, already). Re: Dishwasher install into existing cupboards 4Sep 04, 2013 12:23 pm Pictures would help a lot. Very hard to give you an answer without all the info on the kitchen and the cabinets either side of where you want the dishwasher to go! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 2696 Hi, Can anyone give me approx. price for overhead cupboards. TIA 0 16553 4 11184 |
