Browse Forums Kitchen Appliances 1 Oct 14, 2012 8:17 pm I'm thinking some kind of a gas detector / cutoff would be prudent as part of a new build in order to provide an additional level of safety. Is this feature in all new stoves? Alternatively is it better to have a separate sensor and cut-off valve fitted. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Gas Detector & Cutoff - kitchen stoves 2Oct 14, 2012 8:39 pm Most good brands have a "flame failure" gas cutoff for the cooktops. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Gas Detector & Cutoff - kitchen stoves 3Jun 04, 2013 2:43 am Code in Australia does not require a flame failure safety device (although NZ, the US, Canada, and the EU do) and it is possible to buy quite high-end cooktops where they are missing. Check the manufacturer's brochure carefully and verify by asking if you have any questions. "Choice" is all over this issue and does not recommend any gas cooktop without flame-failure protection. There are two kinds of in-cooktop safeties, one where the automatic ignition kicks on when flame fails to reignite the burner, and one where the gas gets shut off. The gas shut off mode seems more common in Aus. I think both kinds of shutoff rely on sensors that use the tiny electrical charge in a burning flame to determine if the burner is alight or not (non-engineer explanation: the burning flame produces ions which generate a teeny-tiny electrical charge that is read by a sensor). Chris On the threshold of retirement... and trying to check my assumptions at the door 4 10824 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3668 |
