Browse Forums Kitchen Appliances 1 May 07, 2011 10:35 pm I'm asking this question on behalf of my daughter & s.i.l. who are building & would appreciate any ideas for their dilemma ... Behind their oven is a clear window (no splashback). Also there are NO overheads. (**This is going to be a double story home**) Their only option to place a range hood would be from the ceiling. Does anyone know of any 'in ceiling' brands of range hoods or have any other ideas how to solve the problem? thanks in advance Jazz Life is like a lolly, suck it and see Re: Range hood dilemma ... HELP NEEDED 2May 07, 2011 10:43 pm Why wouldn't they get a slide out or under cupboard range hood- sits under the overhead cupboards, it's what we're having my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 Re: Range hood dilemma ... HELP NEEDED 3May 07, 2011 10:50 pm tinkster Why wouldn't they get a slide out or under cupboard range hood- sits under the overhead cupboards, it's what we're having NO overheads ..... thanks anyway Life is like a lolly, suck it and see Re: Range hood dilemma ... HELP NEEDED 4May 07, 2011 10:56 pm Der. Sorry, I'm half asleep! Sorry, I've no idea then my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 Re: Range hood dilemma ... HELP NEEDED 5May 07, 2011 10:59 pm tinkster, there are no over heads. Jazzie, what you are searching for may be an island canopy type range hood. Very similar to a wall mounted version only the chimney/flue is centralized instead of against the wall. This may still hang down in front of the window depending on how high it is and the dimensions of the window. FWIW I don;t see why you couldn't hang a regular wall mount range above the window. You may need to get a high end Schweigen or similar that has a lot of power and an external motor, but it will work much better than a conventional one. Re: Range hood dilemma ... HELP NEEDED 7May 08, 2011 12:03 am elica have speccy ones with carbon ffilters that dont need to be ducted outside!!! Pricey but beautiful. Re: Range hood dilemma ... HELP NEEDED 8May 08, 2011 12:41 am Smeg have some ceiling mounted ones, will there be a space in the ceiling for some ducting? Otherwise I think you can just recirculate the air. http://www.smeg.com.au/Product-74-32cm_ ... S505X.aspx http://www.smeg.com.au/Product-76-90cm_ ... 99X90.aspx Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7014 Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 4139 |
