Browse Forums Kitchen Appliances Re: Oven and Gas Cooktop installation 3Mar 24, 2011 5:29 pm Thanks Kyton, The builder will let me delete them if I want but I am not sure if I should supply my own. Re: Oven and Gas Cooktop installation 4Mar 25, 2011 8:49 am To answer your original question, yes you will need to get a licenced electrician or gas fitter to install your oven and cooktop. You need to make sure when you delete the builders ones he still installs a power cable and gas fitting to the kitchen cabinet where they will go. If your oven is eletric you should find out how many amps it is rated at and tell the builder so they can install the appropriate sized power cable. Most ovens will work off a 15amp supply, but some especially higher end models may need a higher rated cable and isolation switch. Upgrading cable size after the kitchen has been installed isn't easy. Re: Oven and Gas Cooktop installation 5Apr 02, 2011 12:16 am AJW To answer your original question, yes you will need to get a licenced electrician or gas fitter to install your oven and cooktop. You need to make sure when you delete the builders ones he still installs a power cable and gas fitting to the kitchen cabinet where they will go. If your oven is eletric you should find out how many amps it is rated at and tell the builder so they can install the appropriate sized power cable. Most ovens will work off a 15amp supply, but some especially higher end models may need a higher rated cable and isolation switch. Upgrading cable size after the kitchen has been installed isn't easy. Thanks AJW! Decided not to supply our own, just to save the headaches. My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 12715 Hi Chippy, no there isn't, gave it a really good look through and literally opened everything and checked all edges as well. Hence the question, just hoping someone would… 2 2162 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20366 |
