Browse Forums Kitchen Appliances Re: What size rangehood? 2Mar 01, 2011 3:52 pm claireh Hi again everyone! Quick question: we are looking at getting a 4-burner 75cm gas cooktop. What size rangehood should we be after? Cheers! corresponds to the same size of the cooktop or larger if you can accommodate but it also depends of the extraction rate per m3 ideally should be 900 m3 or more for gas if not gas you may need less extraction rate. Re: What size rangehood? 3Mar 02, 2011 8:04 am 900mm Some brands make a 750mm or close to, but unless you like one of those specifically then go 900mm. Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7496 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3663 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3548 |
