Browse Forums Kitchen Appliances 1 Jan 14, 2011 10:25 pm Hi All, Started dismantling our old Kitchen ready for a new one in a few weeks.... Question, with the old stove can i remove this myself and buy a plug to block the gas line till the new one is installed? Has anyone done this before with out using a Gas certified person. Cheers Frank Re: HELP - Need to remove old GAS Stove 2Jan 14, 2011 10:35 pm My advice is not to risk playing around with gas and to use a certified plumber..... Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Re: HELP - Need to remove old GAS Stove 3Jan 15, 2011 7:43 pm Gas all plugged up, was rather simple, $3 plug, some yellow gas tape, tighten tight and check with soap water, no leak and all good, Old oven gone now for major attack on new kitchen.... Re: HELP - Need to remove old GAS Stove 4Jan 15, 2011 8:13 pm justfrank Gas all plugged up, was rather simple, $3 plug, some yellow gas tape, tighten tight and check with soap water, no leak and all good, Old oven gone now for major attack on new kitchen.... Yes it is a simple procedure just make sure to turn the gas off plug it and use soapy water to check for leaks just in case Re: HELP - Need to remove old GAS Stove 5Jan 18, 2011 11:01 am Just remember if somethings happens its on you. Best part of getting a certified tradesman to do stuff like this is its someone else fault if something goes wrong. Good Luck though. Re: HELP - Need to remove old GAS Stove 6Jan 18, 2011 5:31 pm yer i would of got your plumber/gas fitter to do it... 9 Times out of ten the they dont charge since they have to reconnect the new one and should be in the price. Thats what i do anyway. Then its my problem if it leaks not the owners Re: HELP - Need to remove old GAS Stove 7Jan 18, 2011 7:42 pm Totally understand all your concerns and yes there will be a gas fitter when we re-connect, at the moment its all ok after several days and have check for any possible leaks... Regards Frank Re: HELP - Need to remove old GAS Stove 8Jan 19, 2011 11:58 am Yeah I'm just a pessimist. always worried about what could go wrong. Re: HELP - Need to remove old GAS Stove 9Jan 19, 2011 10:59 pm justfrank Totally understand all your concerns and yes there will be a gas fitter when we re-connect, at the moment its all ok after several days and have check for any possible leaks... Regards Frank You lost me mate Reconnecting is just reversing what you have done before. In fact the plumber visiting me for a similar job few years back he knew of some impending reno so he said Well you know khow is done so next time you'll do it yourself. I did no tell him then I had done similar installations overseas before Re: HELP - Need to remove old GAS Stove 10Jan 20, 2011 6:06 pm grinder justfrank Totally understand all your concerns and yes there will be a gas fitter when we re-connect, at the moment its all ok after several days and have check for any possible leaks... Regards Frank You lost me mate Reconnecting is just reversing what you have done before. In fact the plumber visiting me for a similar job few years back he knew of some impending reno so he said Well you know khow is done so next time you'll do it yourself. I did no tell him then I had done similar installations overseas before I think i have to alter my pipe work as the old pipe it pointing straight in the air and might effect where the new kitchen goes, the good thing is that the pipe entry is very low to the ground and might need to find differant fittings to suit new oven, as weeks get closer to the kitchen boys arrive, ill seek some advice from family tradies that i know to help out.... As for the Plug and re-fitting that is a piece of cake 0 1354 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5951 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11839 |
