Wall ovens - how high/low is yours?
It doesn't specify the exact height but it looks like our 600mm wide Oven is 800mm from the floor at the bottom of the oven and 1400mm from the floor at the top. We will have a microwave provision above the oven.
I'm 6'2" and the GLW is 5'5"ish
they had drawn ours finishing 300mm off the floor ( duo oven with m/w on top) , i thought this was way too low , so created another stack next to it too have m/w and oven next to each other. And three draws undeaneath. I was more worried about it being too low for my kids to play with
11
If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that…
22/12/2023
6
Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable…
