Browse Forums Kitchen Appliances 1 Nov 24, 2010 9:06 pm Has anyone had any experience with Fagor kitchen appliances. I'm told they're comparable to Miele, is this true? AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6298 4 14490 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5969 |
