Browse Forums Kitchen Appliances 1 Aug 22, 2010 3:28 pm Hey Its range hood picking time. Anyone have tips or experience with these. Highland bh9027g $1500 Baumatic $500 Westinghouse wrg950cgs $800 Been googling about and still have no idea. Need a strong suction, pref quiet if poss. Thanks ! Re: Rangehood advice 2Aug 22, 2010 4:32 pm We have a Beaumatic (BAH93CG-IS 90CM CURVED GLASS ISLAND CANOPY) It's absolutely stunning to look at, but it's noisey http://i896.photobucket.com/albums/ac165/aaron4erin/rangehood.jpg Re: Rangehood advice 3Aug 23, 2010 11:28 am My only advice on a rangehood is spend as much as you can afford. This piece of equipment will almost single handedly determine whether you enjoy your kitchen or otherwise. I hear more complaints about noisy rangehoods that do nothing than just about anything else. We purchased a Qasair. Australian made, very quiet, very effective and almost universally recommended by the kitchen trade. Will be quite a bit more expensive than the ones you are looking at but if you can stretch, you should. (remember to factor in the ducting costs) Re: Rangehood advice 4Aug 23, 2010 8:35 pm deathgod Hey Its range hood picking time. Anyone have tips or experience with these. Highland bh9027g $1500 Baumatic $500 Westinghouse wrg950cgs $800 Been googling about and still have no idea. Need a strong suction, pref quiet if poss. Thanks ! throw a pice of paper up the rangehood if it sticks because of suction power then it works if does not then forget it Re: Rangehood advice 5Aug 24, 2010 10:36 am Hi we are getting a schweigen rangehood with the isodrive motor (strongest suction motor in range 1200m3-ducted motor sits on the outside of your building) we spent 2K. It has been installed in our new kitchen and boy is it quiet . It is available in a range of designs. We bought the 90cm concealed under mount. Maybe worth a look. Here is their website http://www.schweigen.com.au/ Edited to add: We can't wait to move into our new home next month. Re: Rangehood advice 6Aug 24, 2010 4:43 pm Melrich My only advice on a rangehood is spend as much as you can afford. This piece of equipment will almost single handedly determine whether you enjoy your kitchen or otherwise. I hear more complaints about noisy rangehoods that do nothing than just about anything else. We purchased a Qasair. Australian made, very quiet, very effective and almost universally recommended by the kitchen trade. Will be quite a bit more expensive than the ones you are looking at but if you can stretch, you should. (remember to factor in the ducting costs) +1 We've gone with Qasair too. Sorry, can't comment on the others. Renovation Thread: viewtopic.php?f=31&t=38489 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18555 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6966 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7055 |
