Browse Forums Kitchen Appliances 1 Aug 05, 2010 11:34 am Gudday Chefs and Cookies.... I am used to using a fan forced electric oven with a temperature dial. I'm needing to get used to an older style gas oven with a "Gasmark" dial and I found a conversion in the piccie below. So my questions are: - is the table below relatively accurate - any issues I should be aware of in translating successful electric recipes to gas ones (I'm reasonable comfortable with slow cook stuff...it's the upper end I'm more worried about) - should I even bother and just by a decent oven thermometer and rely on that ...any other tips on the "transition"... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Gasmark to Electric Celsius Conversion...Advice please : 2Aug 05, 2010 12:47 pm Hey TDL, We have a 25+ yr old gas oven (not fan forced), we find if your using current recipes that would normaly be what you would set in a fan forced, we usually add 20deg C or so to whatever the recommendation is. Hence i'd do that addition, then convert to gasmark (assuming its not fan forced). Looking at your table it lines up with the one my fiancee's parents have for their oven. Also just need to allow more time for it to pre-heat being gas vs electric. Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: Gasmark to Electric Celsius Conversion...Advice please : 3Aug 06, 2010 12:35 pm I once lived with a gas oven and found it most convenient that we bought an oven thermometer which hung off one of the wire racks - that way I ALWAYS knew what the ACTUAL temperature inside the oven was...it was also easier than checking against tables. Having said that, our biggest problem was we found that the heat convected differently in the gas oven than in an electric which made frequent turning of, say, a cake a must, as the old gas oven definitely had some "cool spots". Cheers, Earl Re: Gasmark to Electric Celsius Conversion...Advice please : 4Aug 06, 2010 7:13 pm Thanks for the advice guys...much appreciated... mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11117 From the information posted it looks to me your rumpus room is nothing more than extended garage. That will present a number of challenges. Single brick wall between… 2 7765 Because it only states 90mm not if it’s 45mm or 35mm and yes I do have the plans my question was specifically since it’s not the structural value and only to hold… 2 3500 |
