Browse Forums Kitchen Appliances 1 Dec 21, 2009 12:18 am Hi I have a 4 burner gas top with a push button ignistion lighter on it that does not work any more, its completley dead. I have just been lighting the top myself (which does not worry me), But as we will be selling our house soon I was woundering if there is a easy way to fix it? ANY IDEAS THANKS My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: GAS COOK TOP IGNISTION PROBLEM 2Dec 21, 2009 6:05 am Silly question I know, but have you checked if it is battery operated or sparked by a piezzo ignition? A lot of ignitions use a little AA battery hidden somewhere under the cooktop in the cabinetry and these eventually run out. Do you have a brand/model for us? If it is a worn piezzo ignition then it may well be replaceable but depending on the age of the unit the cost to obtain the part and get the work done may not be worth it to you. Cheers, Earl Re: GAS COOK TOP IGNISTION PROBLEM 3Dec 21, 2009 6:11 am camyperth Hi I have a 4 burner gas top with a push button ignistion lighter on it that does not work any more, its completley dead. I have just been lighting the top myself (which does not worry me), But as we will be selling our house soon I was woundering if there is a easy way to fix it? ANY IDEAS THANKS this happened to me once ,the stove was an electric ignition (you hold the button down and hear click click click)but no spark at the burner ,i found that the wire had fallen off the post under the top and wasnt making contact Re: GAS COOK TOP IGNISTION PROBLEM 4Dec 21, 2009 5:23 pm Strumer Silly question I know, but have you checked if it is battery operated or sparked by a piezzo ignition? A lot of ignitions use a little AA battery hidden somewhere under the cooktop in the cabinetry and these eventually run out. Do you have a brand/model for us? If it is a worn piezzo ignition then it may well be replaceable but depending on the age of the unit the cost to obtain the part and get the work done may not be worth it to you. Cheers, Earl My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: GAS COOK TOP IGNISTION PROBLEM 5Dec 21, 2009 5:30 pm arms camyperth Hi I have a 4 burner gas top with a push button ignistion lighter on it that does not work any more, its completley dead. I have just been lighting the top myself (which does not worry me), But as we will be selling our house soon I was woundering if there is a easy way to fix it? ANY IDEAS THANKS this happened to me once ,the stove was an electric ignition (you hold the button down and hear click click click)but no spark at the burner ,i found that the wire had fallen off the post under the top and wasnt making contact Tom There doesnt seem to be any wires hanging off. We might just have to sell as is. ( even though we are near the beach, the houses are not worth to much) My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31248 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3793 |
