Browse Forums Kitchen Appliances 1 Aug 21, 2009 4:52 pm I am doing a major remodel and am replacing my kitchen and my ceilings in that area. At the moment my kitchen does not have external venting for a rangehood. My new rangehood will be externally vented. My question is in what order are things done...put in new kitchen, cut rangehood hole in ceiling, tile back splash where rangehood is, install rangehood and do external venting... The person who is doing my kitchen is a cabinet maker and will not be installing the appliances and my plumber said he doesn't install rangehoods...who should I get to do what when? I am so confused... Re: Rangehood questions 2Aug 21, 2009 5:47 pm We are doing a flat pack. We will be installing all the cupboards first, then putting in the appliances, getting the tradies in for gas and electricity then installing the wall units and the slide out rangehood. The range will need to be vented through our roof and to the outside, straight up, which hubby will do last. Re: Rangehood questions 4Aug 25, 2009 12:13 am sorry i am in wa or i would fit it. i am sure if you try an appliance store a tradie would have left some business cards Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10483 We had this happen to us last year and got charged a variation. Try and give away as much as you can that is usable to charity otherwise if you are in Sydney I have a… 1 4507 Not sure what council area you are in. Some LGA's allow zero lot retaining walls. This usually occurs in greenfield developments but not often in established areas. You… 1 8256 |
