Browse Forums Kitchen Appliances Re: 60cm canopy range hood over a 70cm gas cooktop? 2Jul 17, 2009 3:34 pm The main problem I can see is if you are having overhead cupboards. The residual heat could damage the underside of the cabinets. Personally I would always go for a bigger rangehood then a smaller one. For example my cooker is 110cm and since the matching rangehood is ridiculous money I have sourced a 120cm rangehood which will safely cover all areas of my cooktop. Some things are worth waiting for. Re: 60cm canopy range hood over a 70cm gas cooktop? 3Jul 17, 2009 4:13 pm I actually have a 60cm rangehood over a 70cm gas cooktop all the steam gets sucked straight into it. Mine is not a canopy and can't be seen at all unless you look underneath. Re: 60cm canopy range hood over a 70cm gas cooktop? 4Jul 17, 2009 4:27 pm Miele has the 70cm Intergrated rangehoods Oh! Just saw you wanted the canopy style...silly me Mrs B Re: 60cm canopy range hood over a 70cm gas cooktop? 5Jul 17, 2009 7:19 pm 70 cm canopy styles are available from DeLonghi (BETA70SS), Omega (OR701CXA), Technika (D3-700), Ilve (X39), Qasair (Heritage 700H) and Smeg (KSED75X-1, KD70X-1 and K5020/70) to name a few. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: 60cm canopy range hood over a 70cm gas cooktop? 6Jul 17, 2009 7:54 pm i am going with a 90cm canopy over our cooktop (maybe 70 or 80). i just don't like the splatters and oil / grease getting on the cupboards. we're also having a gap between our canopy and our cupboards so you can get your hand in between to clean. Re: 60cm canopy range hood over a 70cm gas cooktop? 7Jul 19, 2009 9:49 pm Casa2 70 cm canopy styles are available from DeLonghi (BETA70SS), Omega (OR701CXA), Technika (D3-700), Ilve (X39), Qasair (Heritage 700H) and Smeg (KSED75X-1, KD70X-1 and K5020/70) to name a few. thanks casa didnt realise they were made My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 10879 4 10824 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 |
