Browse Forums Kitchen Appliances 1 Mar 05, 2009 9:23 am Hi all,
I was wondering if there is standard dimensions for microwave space ? We ordered PD to put 530W x 330H x 500D dimensions for the microwave and still not sure if it'd look good in the kitchen. I see in Display Homes that microwaves fit perfectly in these spaces and have their own stainless steel frames. How do you go about having a perfect figure for the dimensions ? Any ideas ? Thanks Re: Microwave space, is there standard dimensions ? 2Mar 05, 2009 9:43 am Its a display home - Everything always exactly matches...
And those fronts can be bought. Goto an electrical store, find the type of microwave you want, and see if it will fit. Remember you need extra depth for power cables and such Re: Microwave space, is there standard dimensions ? 4Mar 06, 2009 7:51 am iTalk Hi all, I was wondering if there is standard dimensions for microwave space ? We ordered PD to put 530W x 330H x 500D dimensions for the microwave and still not sure if it'd look good in the kitchen. I see in Display Homes that microwaves fit perfectly in these spaces and have their own stainless steel frames. How do you go about having a perfect figure for the dimensions ? Any ideas ? Thanks The standard microwave space I use is when not using a frame, is 600w x 400h x 450d Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9960 Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3582 dimensions on your original plan are inconsistent and with accurate dimensions (including site plan, upstairs and down) i could make a proper scale drawing with furniture… 3 7518 |
