Browse Forums Kitchen Appliances 1 May 23, 2024 7:13 pm I get an error message on my dishwasher (whirlpool ADG 7580) indicating that the water inlet is closed. I think there is a problem with my aquastop. I removed the cover to look at it, and this is how I think it works: If there is a leakage in the inner hose, the outer hose and the aquastop house fill up. The sponge expands, pushing the spring-loaded mechanism back which releases the magnet. The magnet is normally trapped in a repelling orientation and flips around when released. I did a simple test where I tried to pour water into the hose (from the top / the blue ring) with the magnet in both directions but the water did not pass the valve (the filter was removed). Therefore I suspect that it is broken, but I don't understand how. Am I missing something here? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Its the flashing and is normal. Some builders cover them up others just leave them handing. You can cover it up with an aluminium bracket or ask the builder. 7 12058 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5880 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 11047 ![]() |
