Browse Forums Kitchen Appliances Re: Fisher & Paykel E3728 fridge leaks water onto the floor. 2Mar 14, 2023 8:59 am Kafka My Fisher & Paykel E3728 fridge leakswater onto the floor. This only happens a couple of times a day. Can I fix it or do I need to call a repair man? this is the question only you can answer. are you comfortable taking appliances apart and fixing them? Re: Fisher & Paykel E3728 fridge leaks water onto the floor. 3Mar 22, 2023 7:56 am I have watched a video on how to clear the pipe which takes water (condensation?)from the freezer to the pan underneath the fridge but unfortunately it was for a fridge with the freezer at the top. My fridge has the freezer at the bottom. Would I be correct in assuming that I would have to access the tube from behind the freezer at the bottom? The video suggested that the probable cause of the leakage was a blockage in the pipe. If the build keeps returning, thats a plus!! but it would also suggest he doesnt know what his looking for, an independent inspector should have fresh eyes on the issue. Good luck 1 8620 I had this sunroom built onto my new brick house and it leaks when we have a big rain. The installer says the only thing to help would be to seal the brick wall it is… 0 7812 Hi! It sounds like you’ve done a great job diagnosing the issue so far. The symptoms you’re describing—especially the loud click and the increased power… 4 19295 |
