Browse Forums Kitchen Appliances 1 Jan 20, 2021 2:06 pm I have a Miele steam oven that stoped working a couple of years ago and finally took it out to get it looked at and it requires a new board - around $500. I’m happy to go ahead with the repair, however once it is up and going again, are there any parts in the steam system that may have corroded over this time? Obviously I’d run a descaler through it first, but I’m just not sure about the internal parts of steam ovens or whether there is a risk of any corroded metals or plastics could end up in the steam circuit that would contaminate food? Re: Is it safe to use steam oven after 2-3 years not used? 2Nov 16, 2021 3:41 pm Georgeo I have a Miele steam oven that stoped working a couple of years ago and finally took it out to get it looked at and it requires a new board - around $500. I’m happy to go ahead with the repair, however once it is up and going again, are there any parts in the steam system that may have corroded over this time? Obviously I’d run a descaler through it first, but I’m just not sure about the internal parts of steam ovens or whether there is a risk of any corroded metals or plastics could end up in the steam circuit that would contaminate food? Hi I don't know exactly, but before using the oven call an expert to check it. listen to the expert's opinion then decide Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3516 Joe, it depends on your certifier but we are noticing the ones we deal with are really cracking down. So i would recommend you follow your approved landscaping plans to… 4 11009 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7748 |
