Dishwasher space in tight kitchen
They can be side-by-side and also below a wall oven in the tower unit. Another house had 2 x singles but one each side of a farmhouse style sink.
Hope some of this helps?
1. You could get a freestanding 600mm dishwasher and place it somewhere in the kitchen that works.
2. If that stack of drawers is 450mm wide, then you could take out that section of the kitchen and install a 450mm wide built-in dishwasher.
3. A small bench top dishwasher.
The distance to the plumbing is not a huge deal as you can buy extensions for the inlet, waste and electricity. However, it will mean running that through the back of few other cupboards, but a good installer should be able to do it neatly.
- Select a slimline dishwasher.
- Place the dishwasher underneath the sink.
- Put the dishwasher in the corner.
- Add the dishwasher to the end.
- Hide your dishwasher behind a cupboard door.
- Strip back the kitchen.
- Match the color of your kitchen.
- Color blocking.
2
You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap…
31/01/2024
I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to…
22/08/2023
1
Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution…
