Browse Forums Kitchen Appliances Re: Installing Bosch SMS46GW01A Dishwasher - Under bench 4Jun 10, 2021 2:17 pm dracnath I hate to tell you but you may struggle to run your kick board through with that dishwasher. It's a free standing model which is designed as a standalone machine (similar to a washing machine). It already has a kickboard attached and the way the door swings probably won't allow the kickboard to run through. You may get lucky but it's normally the under bench model that would have been preferable. The one you have got will be fine, but may not be able to give you that "built in look" you wanted. Hopefully it works out for you. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Installing Bosch SMS46GW01A Dishwasher - Under bench 5Jun 10, 2021 2:22 pm And I think the grey lever is the childproof lock. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Installing Bosch SMS46GW01A Dishwasher - Under bench 7Jun 11, 2021 10:17 am You can remove the top of free standing dishwashers and it helps them look more built in. The kids are usually heavy to act as a counter weight for when you open the dishwasher and there is nothing holding it in place. Once it's under a bench you don't need the counter weight so can remove the top. But it doesn't change the design at the bottom where the kickboard would run through. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 A lot of those Covenants are put in place at the time the Developers are still involved and marketing a certain look and they get ignored or expire after a time. If the… 1 26517 ![]() When I worked on leveling my shed, I found that using adjustable base plates or shims was a pretty effective way to stabilize it. Another approach I tried was building a… 1 8360 ![]() You are definitely going to have to flash that from the start of the flat roof and down over the flue. You can then dektite that to prevent water penetration. You'll need… 4 9711 ![]() |
