Browse Forums Interior Decorating Lounge 1 Jun 12, 2019 11:10 pm We are couple of months away from moving into our new home. Little confused with lounge room setting, Initially we thought about putting an L shape lounger (7 seater) but now considering a 3 seater + 2 seater. Not sure what would suit better? It is decent sized open plan lounge area. Please give advise how to best furnish the lounge+tv room. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Lounge room furniture advice pleaseeeee! 2Jun 13, 2019 10:57 am This is a difficult layout because of the proportion of the room and necessary circulation space. I would suggest moving the location of the TV and using a combination of 3 seater sofa and armchairs. The wall between your 2 rear windows is the perfect proportion for a wall mounted TV. This arrangement also allows for good flow through to your rear sliding door, and good circulation space around your kitchen. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Lounge room furniture advice pleaseeeee! 3Jun 13, 2019 10:27 pm amilelka This is a difficult layout because of the proportion of the room and necessary circulation space. I would suggest moving the location of the TV and using a combination of 3 seater sofa and armchairs. The wall between your 2 rear windows is the perfect proportion for a wall mounted TV. This arrangement also allows for good flow through to your rear sliding door, and good circulation space around your kitchen. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks a lot amilelka, that's invaluable advice, so grateful! Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13733 First time building 2 storey home in NSW. Below Current plan have separate balcony. But thinking to do a multipurpose lounge with balcony (kind of sunroom) in first floor… 0 4784 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18333 |
