Browse Forums Interior Decorating Lounge 1 Aug 12, 2008 10:06 am hi every one this is a first for me I have read all the great help you give and hope you have some advise for me
I am building a new home on a small acerage in qld I want to place a colourbond shed for the boys first than build the home I do like the dune colour for the house roof after reading all you q&A .Walls are render undecided? I like the off whites/ grey whites with lighter shades of dune mix in there ie. gargage & entances and may be surfmist garage doors possible light grey window trims. THe question is what colour do I do the shed I don't want to it to stand out what do you think of Dunne walls and roof will it be to much I don't like the way they put different colour doorson sheds I want the house to be the main focus not the shed as it will be ivisible from the driveway beside the house just not level with the house (set back a little) We do have alot of trees around for the back drop hope this sets a picture any help would be great Re: Colorbond shed colour 2Aug 12, 2008 10:19 am Hi and welcome to the forum.
We are in the process (well we have ordered just waiting for it to be ready) of getting a shed. We chose the colour to compliment our house - so I think if you had a dune roof, then a dune shed will be fine. We have gone all the same colour, but was advised by the salesman to do the spout and barge in a contrasting colour to break it up. Hope this helps. Paula Re: Colorbond shed colour 3Aug 12, 2008 6:32 pm Hi lostlozza….welcome to the forum.
I have just helped with a new home in QLD, we used Bushland for the roof and Dune for the walls. This choice came about from the amount of trees on the property, and I wanted the roofline to blend in and not stand out. Possibly this would be a good combo for you? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Colorbond shed colour 4Aug 14, 2008 10:24 am thanks Michelle and Paula
I am a bit worried about dark roof colours as it faces west alot in QLD that was why i went dune roof I realy like surfmist but every said It will mark with the trees. I am worried if I pick the wronge colour for the shed the house is going to be all wronge too If I did the shed all dunne roof and walls & maybe surf mist gutter on shed?Do you think I could have dunne house roof and that light grey/white colour I see alot of I don't know its name for the walls ? I am thinking of silver window trims front door double doors timber and glass Gutter/facier? ( like you Michelle I think they should be same as roof but I just don't know I don't want to much Dunne ) Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4899 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5416 Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3428 |
