Browse Forums Interior Decorating Lounge 1 Dec 09, 2016 4:38 am Hi all, Just after some tips from hopefully some seasoned painters, or even professional painters? Anyone else who has done their own DIY and done some hard yards reseach and learnt some painful or insightful lessons on the whole process - please post and reach out to share! New WA house so construction is diff - double brick, with the render and white set float finishing off the walls with plaster. Assumedly been told one must use oil based sealer to prep, not the primer or 3 in 1s?? but water based paint is ok?? My main questions/areas I'd love some feedback: 1) My building supervisor and the painter mention that one should "patch" all the holes and chunks and imperfections of the white set plaster after sealing all the walls completely. Prior to this I assume one should sandpaper down any imperfection/loose bits on the surface before sealing? Must it be wiped down and washed/cleaned of dust prior to sealing? Other DIY'ers and paint stores seem to say patch and then sand down everything before sealing it aall completely, that way everything is all sealed? If not the builder's/painter suggestions would involve resealing filled parts with acrylic sealer supposedly? Does that work/how they do it by practice normally? But doing it this way around means sanding filled parts does not 'eat' into unsealed plaster? Difference or none at all? Thoughts? 2) Regarding patching plaster - what tool do I use, and what type of "filling" compound do i use? I see spatula and filling blades mentioned but why the two different tools - when should one use? I thought "putty" is what I need or some sort of plaster base, but it seems for little scratches, chips of plaster i have been told to use "Sealey's spakfilla" or something? Bunnings sells this. Is that correct? Looking for something just to scrape onto the hole/area, wipe it generally flat then finish off with sandpaper? If not, what should I get? 3) What other prep work before sealing or filling should I do? Is just water and damp rags for a new build, as sugar soap is for existing walls right? 4) Buying all my materials, paint and accessories. Any tips on choosing paint brushes, rollers etc? There is a million brushes in even one brand - Monarch, in bunnings. They range from brushes also for specific surfaces/areas, and for each area there are diferent filament, material, and even with rollers the cheap budgets vs microfibre vs sheepskin (which my friend said is the one I should be using). Just what and how do I decide between brands? I want to have enough brushes, rolllers and whatever paint trays or painters buckets are necessary so we could run (friends popping in and out over xmas break to help) 2 or so teams of 2 (one cutting in, one rolling/doing the bigger paint, maybe a 3rd person if people power permits to tape stuff up) - but I don't want to overdo and buy too many sets or too many materials not needed? In that regards what 'necessities' do painters regard? Generally - material aside for now (as i have no clue) i figure i need: cutting in brush, normal brush (but what size generally is best?) , roller (again what size, what material? i have been told go the budget ones for sealing, and quality microfibre for rolling topcoats), extension pole, ladder/painter platform thing?? some painting buckets (can't i just get any container and pour paint in for peopel to use a brush??), sandpaper (what sort of sandpaper number does one use to sand down filled/patched plaster and the like?). Also figure I need plastic dropsheets in general, canvas dropsheets for immediate areas? I need something which makes life easier for cutting in to edges where carpet meet and even what sort of painters tape should i get to ensure sticking onto cornices or painted window frames aren't pulled off later when it is removed? 5) is a ventilation mask do anything/help with smells or safety as far as the sealing process goes (i've heard sealer is really bad smelling - the oil based) 6) what sort of guide to how many m2 is painted per 1 litre of paint, and therefore how much sealer would i need too? 7) If anyone had any nifty techniques, tips or tricks from the cutting in all the way to painting by brushwork, rolling, or even how to 'prep' the walls and patching, i'd appreciate it!! I'm sure many have done the research and hard yards by making mistakes so it would be great to hear them so i can avoid it as best as I can. for example i did not know until recently that oil based sealer would ruin my brushes and rollers, so get a cheap budget pack material and just get it on the walls then throw it out -dont even wash it?? Per the discount paint store... And wash out those that are for the topcoat (water based paint). Appreciate have any good articles or complete video series on prep through to finish, techniques, hints and tricks on painting? I've seen dribs and drabs and all but looking for a real authoritive source that goes into great detail. It's harder still to find something geared towards WA based - plaster etc, as many vidoes or instructions go off alternate materials/houses located outside of WA. 8 ) WHat brands for paint? Or even brushes, accessories etc (that are considered great quality and worth buying for even a DYI project)? I'm thinking of limiting most of my paint and supplies/accessories to bunnings, and also the discount paint shop nearby here(paint for less - damaged cans and the like for cheaper, all the standard brands). So brands from bunnings and P4L would be say british paints, and what i'm thinking is most likely: Dulux and taubmans. There is a topdek supasealer which I've been recommended, however I am thinking of just sticking with and going the dulux sealer binder, or the taubmans version? I then can't work out taubmans endure or the good old dulux wash and wear? I plan to live in it for the short term until we work out our lives, but if i move out and rent it i am mindful of choosing a paint "type/technology" or colour that will set us up for tenants. That said I know tenants will find a way to discolour or chip your paint anyway, but if there is any paint brand or type or colour that would slow this process down, I'm all ears! Then the next hardest is choosing one colour that wills suit all the way throughthe house! 4x2... Appreiate any advice/help. At the moment i'm willing to get out ther eand try painting but just the prep work in what to buy and what type of item or tools is mind boggling for a first timer. Hi there, We’ve recently had plans approved to add a 1st storey addition to our existing house for a growing family in Sydney. With the current cost of building… 0 4511 |
