Browse Forums Interior Decorating Lounge 1 Aug 18, 2015 1:14 pm I hope this is in the right place to ask the question. I am searching and searching for the perfect pendant for the void and stairwell. I hate pendants so much right now and I need some advice! Because I have chosen mostly white throught the house apart from a few splashes of colour Kitchen Splashback glass - Dulux Dubilation Study nook splashback - Dulux Grass Court And the back of our island bench will be built by hubby will be legos. So you get the idea of all the colours involved there. Like this... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I think I would like a colourful pendant for the void and stairwell to match the splashes of colour in the rest of the house. I was thinking of these, but they are smallish. I would probaly need 3 or 5 to fill the void area, and 3 for the stairwell. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And another option is these, probably need 7 or 9 in the void and 5 in the stairwell. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is the house plan to get an idea. http://i292.photobucket.com/albums/mm2/sandra77_photo/Euston%20pg1%20pool%20change.jpg Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Main colours throughout Internals Ceiling /Cornice - Dulux Vivid White (unless it is an upgrade for the colour otherwise it will be ceiling while) Walls - Vivid White Low Sheen Skirting / Architrave - Vivid White Gloss Windows / Reveals / Frames - Vivid White Gloss Doors - Vidid White Gloss Window Treatments - some aluminium wood look louvers, otherwise glass louvers elsewhere, obscure glass louvres in wet rooms Flooring - mixed hardwood Carpet - only in theatre - dark purple Tiles - all wet areas and games room downstairs - Gretta Grey Matt - all wet areas upstairs - Gretta Charcoal Matt - feature tiles in all bathrooms will be LD Illusion Sapphire Mosaic - feature tile in Laundry Yellow Gold gloss Lighting - all white downlights, all white ceiling fans NEED HELP WITH PENDANTS! ********************************* Externals Roof - surfmist Gutters - Woodland Grey Fascia - Woodland Grey Downpipes - Eaves - Soffit to underside of Eaves, Verandas & Portico’s - white Posts - Timber oiled Masonry Walls - Grey Pebble Cladding - upper level Scyon Grey Pebble Windows - White Doors - Timber stained Deck - Kwila I hope that is all the info you need. PHEW! Sandra Re: Colourful Pendant light and sizing advice please 2Aug 23, 2015 2:35 pm Just saw your post sandra77, how you going, still need help? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Colourful Pendant light and sizing advice please 4Aug 27, 2015 6:38 am I've been really busy....I'll try and get into the form in the next couple of days. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Colourful Pendant light and sizing advice please 5Sep 22, 2015 12:15 am That first light is FANTASTIC! Can you find another larger light which is a similar shape (stepped angles) in solid white to team with two of those coloured ones hung at different levels? If so, worth printing out and pasting up together to see what that might look like. In my head, it looks great ... But it's messy up there Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18077 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11707 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17375 |
