Hi all
I have recently built a house and am stuck with what to do with my hallway niche. They are approx 42cm wide and 2.10 high. Once I can work out what to do with hallway niche I should be able to easily fill the other niches.
Thanks
Browse Forums Interior Decorating Lounge 1 Jul 12, 2015 11:27 am Hi all I have recently built a house and am stuck with what to do with my hallway niche. They are approx 42cm wide and 2.10 high. Once I can work out what to do with hallway niche I should be able to easily fill the other niches. Thanks Re: Hallway Niche 3Jul 12, 2015 11:45 am Put either a long tall painting or a tall vase with long decorative sticks. Sorry I am not good at this. Might cheaper to changer your idea of what makes a home, have you considered building a porch? 2 51774 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61339 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8506 |
