So after a few quotes of around $5000 we've decided to paint it ourselves and would like a little bit of help with what sealer to get and how many litres etc. it's 235 square metres inside and we want to do 2 top Coates of dulux paint but have read on here people using enamel sealer that was tinted.
Any help or hints much appreciated.
Painting DIY
dulux primer if you want
2 cotes final colour
can use water based paint over the sealer. Also someone suggested to add the tint of the finished paint to the sealer and then you only need 2 coats instead of three altogether. Has anyone tried this?
Just to revive my previous post, I've been told youNot sure about adding a tint to it but I hope you're right...the less coats, the better!
Tinting undercoats is only good for plasterboard houses (over east) or when painting over a very dark wall with a light colour where the acrylic sealer undercoat (higher opacity) is tinted which allows coverage with 2 coats.
1
Assuming the structure of your cabinetry is good then I would DIY everything as follows: - replace your counter tops entirely, - replace all drawer runners with soft close…
4/10/2023
3
Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters…
