Browse Forums Interior Decorating Lounge 1 Oct 06, 2014 2:28 pm Hello Guys, We recently moved into this house basically upgraded from Unit to a house so excited to start putting the things together. We are looking for your inputs to improve appearance of our lounge and rumpus room area. Struggling with visualizing - furniture layout of lounge room (tv, sofas, wall frame/art, coffee table, any other decor items etc what to add and where) - also ideas and what to do in rumpus room area Here is our house layout with appro measurements Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Appreciate your inputs and ideas. Thanks Anna and Glenn Re: Improve appearance of lounge and rumpus room area 3Oct 09, 2014 5:55 am Hi Anna, I'll try and look this over in the next couple of days. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Improve appearance of lounge and rumpus room area 4Oct 09, 2014 6:45 am Michelle Hi Anna, I'll try and look this over in the next couple of days. Thanks again Michelle, looking for your valuable inputs Re: Improve appearance of lounge and rumpus room area 6Oct 13, 2014 6:05 pm Which room are you putting the TV in? You've changed from before? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Improve appearance of lounge and rumpus room area 7Oct 13, 2014 6:31 pm How about this for you to work off.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Just realized the chase should have the long end at the other end of the set-up, away from the side door! You look like you have changed your mind what room the TV is going to be in, so I changed your placement of furniture. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Improve appearance of lounge and rumpus room area 8Oct 14, 2014 11:52 am Hello Michelle, Awesome, thanks for your valuable inputs as always Appreciate your time. Here are some points from my end : 1> We haven't really decided to put the TV in rumpus room Its just an idea if we are unable to get better design setup for our lounge room with TV. Moreover, the rumpus room does not have a antenna aerial connection so if we plan to put TV there we will have to spend bit more to electrician for getting it there. So we are open to consider TV in lounge room as well. So please let me know what design do u think for that ...appreciate if you can paste image for that So in that case rumpus room will need more idea as in what to setup there and how. Anna Oct 07, Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 14454 From the information posted it looks to me your rumpus room is nothing more than extended garage. That will present a number of challenges. Single brick wall between… 2 9222 First time building 2 storey home in NSW. Below Current plan have separate balcony. But thinking to do a multipurpose lounge with balcony (kind of sunroom) in first floor… 0 5070 |
