Browse Forums Interior Decorating Lounge 1 Sep 20, 2014 7:59 am We are looking for a mid-brown (no reds or yellow tones) laminate for our build. I've looked at a couple and would appreciate it if you could post pictures of the following: * Laminex Divine Oak * Formica Urban Wood Can someone id the laminate used in the following picture from Metricon: http://ourphoenixbuild.files.wordpress.com/2014/09/phoenix_35_robe.jpg I looked at the following laminates but aren't quite what we're after: * Laminex Pesto Linea (yellow tinge) * Laminex Mushroom Linea (pinky tinge) * Laminex Natural Zebrano (very stripey) * Formica Idyllic (a touch light) Thank you. Our Phoenix Build: http://ourphoenixbuild.wordpress.com/ Re: Timber look laminate from Laminex or Formica 2Sep 24, 2014 7:17 pm Love it!!! If its European, you may not find it....also, it could be timber. Check out Polytec - "European Walnut" Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Timber look laminate from Laminex or Formica 3Sep 24, 2014 7:23 pm Should just add, its high end.....$$$ probably timber veneer. So I'd look at getting as close as possible with the laminates, but doubt you get will get exact. Close is good! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Interested in getting either the Polytec Boston Oak or Palace Peak for kitchen cabinets. Looking at the Boston Oak ones, it appears that the colour varies significantly… 0 9167 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15904 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11576 |
