Browse Forums Interior Decorating Lounge 1 Sep 15, 2014 1:29 pm There are so many laminates to select from and would like to hear the guidelines I should be following when selecting them for a new build. I would like to know whether I should try to use the same laminate colour in the kitchen, laundry and bathrooms, or should they be different but in the same tonal family? Should we stick to one timber look colour and a plain colour for the other? Also, are there rules relating to the finishes? Should it be gloss in the bathrooms and laundry? Our Phoenix Build: http://ourphoenixbuild.wordpress.com/ Re: Guidelines in selecting laminates for new house build 2Sep 15, 2014 1:43 pm I really don't think there are any hard and fast "rules" as long as they suit the environment they are in, it's fine. Some like a uniform theme throughout the home, some like to experiment with different options in different rooms. We have our bathroom and ensuite the same, different in the laundry and different again in the kitchen. But used the same tiles throughout bathroom, ensuite and laundry to tie them together a bit. Its really up to you! I'd decide on the tiles you want for the bathrooms and laundry and work from there. Kitchen, maybe pick your benchtop and see what fits with that - also take into account what main flooring type you'll have throughout the house - your kitchen laminate will need to tie into that. Thread: viewtopic.php?f=31&t=66299 Slab: 16/6/14 Frame: 4/7/14 Roof: 22/7/14 Lock Up: 20/8/14 Fixing: 26/8/14 PCI: 9/10/14 Handover: 20/10/14 Re: Guidelines in selecting laminates for new house build 3Sep 16, 2014 6:37 am sydfam There are so many laminates to select from and would like to hear the guidelines I should be following when selecting them for a new build. I would like to know whether I should try to use the same laminate colour in the kitchen, laundry and bathrooms, or should they be different but in the same tonal family? Should we stick to one timber look colour and a plain colour for the other? Also, are there rules relating to the finishes? Should it be gloss in the bathrooms and laundry? Quick point here....DO NOT lay Laminate in your bathroom or laundry. If you want a wood look in these spaces go for a glue down vinyl plank. Personally I like a uniformed look throughout a home. Its quite off putting moving through a home with lots of different flooring. - Use the same laminate in all heavy areas, - Tiles in the wet areas - Carpet in the bedrooms and lounge/theatre Make sure all flooring complements each other and their surroundings with colour. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Guidelines in selecting laminates for new house build 4Sep 16, 2014 7:44 pm Thanks deluxes and Michelle! What are your thoughts on dark timber look laminates like Laminex Burnished Wood, Espresso Ligna, Licorice Linea and Smoky Sapelle in the Nuance and Riven finishes? Do you think the dark laminates will date quickly? I think if used correctly they can look smart but hesitant to use them everywhere as we have dark grey tiled floors and may make the home feel too dark. Our Phoenix Build: http://ourphoenixbuild.wordpress.com/ Re: Guidelines in selecting laminates for new house build 5Sep 16, 2014 7:53 pm Don't get a laminate with a texture as they are much harder to keep clean. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Guidelines in selecting laminates for new house build 6Sep 16, 2014 8:17 pm bashworth Don't get a laminate with a texture as they are much harder to keep clean. Thanks bashworth. I was told they are easy to maintain. Thanks for the advice! Our Phoenix Build: http://ourphoenixbuild.wordpress.com/ Re: Guidelines in selecting laminates for new house build 7Sep 17, 2014 9:19 am sydfam Thanks deluxes and Michelle! What are your thoughts on dark timber look laminates like Laminex Burnished Wood, Espresso Ligna, Licorice Linea and Smoky Sapelle in the Nuance and Riven finishes? Do you think the dark laminates will date quickly? I think if used correctly they can look smart but hesitant to use them everywhere as we have dark grey tiled floors and may make the home feel too dark. Dark flooring no matter what it is will show everything! Meaning you will be cleaning more often, I'd go a mid dark. Whilst dark is in now, its on its way back out again..... Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Guidelines in selecting laminates for new house build 8Sep 17, 2014 9:39 am They've mentioned they have dark grey tiled floors throughout the home and are looking for the best laminate to match (as in cupboard/cabinet laminate). Thread: viewtopic.php?f=31&t=66299 Slab: 16/6/14 Frame: 4/7/14 Roof: 22/7/14 Lock Up: 20/8/14 Fixing: 26/8/14 PCI: 9/10/14 Handover: 20/10/14 Re: Guidelines in selecting laminates for new house build 9Sep 17, 2014 10:26 am deluxes They've mentioned they have dark grey tiled floors throughout the home and are looking for the best laminate to match (as in cupboard/cabinet laminate). WOW...just left the flooring forum, you can tell eh!! lol So my last reply's were based on laminates for the floor, that's the trouble with scooting from forum to forum. Sorry!!!! Will have another look later for you, home with the flu...again. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Guidelines in selecting laminates for new house build 10Sep 17, 2014 10:36 am hahaha I had to go back and read from the top to make sure as well! hehehe the flu sends us all a bit batty, but you gave some good info on laminate floors was given nonetheless Thread: viewtopic.php?f=31&t=66299 Slab: 16/6/14 Frame: 4/7/14 Roof: 22/7/14 Lock Up: 20/8/14 Fixing: 26/8/14 PCI: 9/10/14 Handover: 20/10/14 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17587 1 10481 hi guys. Please be nice. First time home builder in Qld. I would like some feedback please on whether I should build my granny flat first before my main house at the… 0 4587 |
