Browse Forums Interior Decorating Lounge 1 Jul 14, 2014 12:28 am Does anyone know what the name is of the lines that some people have in their render. I googled and found something called Ashlar Cut. But I'm not sure if thats exactly what I'm after - basically I see some people have like a design of lines (not a lot) in their render on the facade. If you have this, how did you ask the builder for it - what did you call it? Does it cost more? Thanks for your help! Re: Cement Render 4Aug 04, 2014 7:17 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Cement Render 5Aug 04, 2014 7:21 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Cement Render 6Aug 04, 2014 9:31 pm Thanks Michelle, yes that is exactly what I meant. I don't need it to be that fancy, but essentially just the idea of the detailing in the render itself. I just don't want plain flat render everywhere. So was thinking maybe a couple of lines close together to divide the sections and then repeat the pattern 1/3 of the way up again. Or something to this effect. Not too sure, what exactly; I just like the idea and was wondering if anyone who has done this could tell me what to ask the renderer - and does it cost a lot? Thanks Re: Cement Render 7Aug 05, 2014 6:28 am I didn't think you would be able to do it with a normal render, then I remembered, I have seen it done somewhere just can't remember where! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4586 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3218 Hi Alex, Thanks for the reply again. I had a chat with the builder, he said he will use primer, then hydrotec which comes with colour and sealer as well. A Renderer I… 12 18177 |
