Browse Forums Interior Decorating Lounge 1 May 10, 2013 2:51 pm Hi all I am looking at the window furnishings for our yet to be built house and I would love some opinions please. The questions I have are: 1. the front 2 rooms are across from a streetlight - and I am wondering how much light will get in if I use shutters? does anyone have this situation - and can let me know what it is like for them (reason - I have a streetlight and venetians and had to put up a blockout curtain over the top for myself. in our new home he sleeps a lot better than I do - but I don't want it lit up like a beacon 2.I am considering bifolds on 2 stacker doors. has anyone done this and regretted it? 3. what is easier to manage over a bathtub - shutters or venetians? 4. for the ensuite I have a skinny 610mm wide x 2057mm window. what would look better here - a shutter or venetian. looking forward to any advice others have had. It certainly is a dilema Sandy Building the "Symphony Grande" with Masterton Homes If I ever remember to update it - check out my blog http://fernadell.blogspot.com.au/ Re: Shutter advice 2May 11, 2013 6:51 pm sandyglenn23 Hi all I am looking at the window furnishings for our yet to be built house and I would love some opinions please. The questions I have are: 1. the front 2 rooms are across from a streetlight - and I am wondering how much light will get in if I use shutters? does anyone have this situation - and can let me know what it is like for them (reason - I have a streetlight and venetians and had to put up a blockout curtain over the top for myself. in our new home he sleeps a lot better than I do - but I don't want it lit up like a beacon This depends on the blade size of the shutter, if you go with the 50mm blade on the shutters they lock really tight compared to a 60mm! 2.I am considering bifolds on 2 stacker doors. has anyone done this and regretted it? 3. what is easier to manage over a bathtub - shutters or venetians? Venetians, as you can have the wand made longer which meanes you don't have to reach so far over. Be warened.....timber is not recommender in moist areas, you are better off going with the faux timber. 4. for the ensuite I have a skinny 610mm wide x 2057mm window. what would look better here - a shutter or venetian. Venetian..... looking forward to any advice others have had. It certainly is a dilema Sandy Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Shutter advice 3May 12, 2013 10:50 pm Thanks Michelle for your reply I am starting to think that I will go venetians - as I won't worry then if I need to add to the look by putting a curtain over it. I don't really like the look of the 50mm shutters - I think they look better at 89mm .... and yes - I was always going to do faux wood in the wet areas Sandy Building the "Symphony Grande" with Masterton Homes If I ever remember to update it - check out my blog http://fernadell.blogspot.com.au/ Re: Shutter advice 4May 13, 2013 7:16 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15570 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13817 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6888 |
