Browse Forums Interior Decorating Lounge 1 Aug 01, 2012 8:38 pm Hi all, Does anyone know if it's possible to modernise an old built-in-wardrobe (bir)? Basically, my house has 3 rooms with bir but they were built at different periods of time. The oldest bir has old wall-paper at the back of the wall, heavy doors and different colours to the rest of the bir. Is it easier to get someone to replace the bir or can older bir somehow be rejuvenated? Thanks. Re: built in wardrobe 2Aug 02, 2012 7:27 pm your bir is no different to your house, you can fix a house, so you can fix the robe. You can either get someone in to remake and redesign the robe or have a go yourself. Depends how much time and money you want to spend on the project. http://www.canterburyrobes.com.au/ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4983 Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3111 DIY, Home Maintenance & Repair We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some… 0 12925 |
