Browse Forums Interior Decorating Lounge 1 May 04, 2012 1:39 pm What the best way to put framed pictures up in a rental property? My friend has just moved into a new place and is worried about damaging the wall with his paintings. Need some help? Painting size is around 100*40cm Re: Framed pictures up in a rental property 2May 04, 2012 2:53 pm Hi, it's a pity picture rails are hardly used any more except on traditional style homes. Other than that you need the 3M picture hooks, strips etc. There are probably other brands out there too. However, whatever you choose goes by weight of your painting or photo as well as size. I think the largest bears up to 2Kg load...They are available at office supply stores. Re: Framed pictures up in a rental property 3May 04, 2012 3:23 pm Just be careful of them We used the appropriate sized 3M hanger in our place and it ripped the paint and part of the plaster off the wall. No idea how it happened but clearly the person who renovated our place didnt do something right Re: Framed pictures up in a rental property 4May 04, 2012 3:35 pm Whoa!! Sounds more like a very cheap plaster job to me- too much sand- rather than fault of the product!
Re: Framed pictures up in a rental property 6May 04, 2012 5:00 pm Sure, so my suggestion is that the renter should hang a hook on an inconspicuous area first to check that the plaster work and paint is sound and then after a day or so try to remove it. Re: Framed pictures up in a rental property 7May 04, 2012 7:19 pm Peter Clear What the best way to put framed pictures up in a rental property? My friend has just moved into a new place and is worried about damaging the wall with his paintings. Need some help? Painting size is around 100*40cm I would advice your friend to get permission from the property manager first before hanging anything. 9 times out of 10 they really don't mind. But better to check first. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com DIY, Home Maintenance & Repair Follow up question - any ideas on how to set up a portable air conditioner through this kind of window? 1 6226 Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7020 |
