Browse Forums Interior Decorating Lounge 1 Feb 19, 2008 12:50 pm how do they achieve this hidden tops to the curtains?
(borrowing your pic thankyou) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ we actually tried to get this look but couldnt work it out... it doesnt work if you have cornice? and has to be full wall? do they just stop the ceiling early and leave a gap? it looks very fab Re: how do they do this look? ceilings/curtaining 2Feb 19, 2008 12:58 pm If you take a good look…..you will notice the bulk of the ceiling is lower than the outline.
Therefore creating a “Bulkhead” effect around the room, it’s done a lot in 5 star hotels. I think it looks really classy…..and a neat look for the curtains. What’s thrown this photo out is the wallpaper was laid lower again, creating an illusion on that wall. ![]() Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: how do they do this look? ceilings/curtaining 3Feb 19, 2008 1:02 pm Your average builder won’t do this ceiling for you!!!!!
They are boxed and cemented, which is why you see it a lot in hotels. To do this with plaster would cost a lot more,…..it can be done!!!! But most builders won’t do it…… TO HARD!!!!! ![]() ![]() Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: how do they do this look? ceilings/curtaining 5Feb 19, 2008 3:23 pm ![]() Your average builder won’t do this ceiling for you!!!!! They are boxed and cemented, which is why you see it a lot in hotels. To do this with plaster would cost a lot more,…..it can be done!!!! But most builders won’t do it…… TO HARD!!!!! ![]() ![]() Not boxed and cemented, it's plaster. Services run in the space above, A/C, sprinklers etc. Old Home Restoration / Renovation That's correct. The fan coil unit that sits in the roof normally has 2 or 3 outlets. These are larger ducts that then get get split into smaller ducts for individual… 7 4740 ![]() Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 9483 ![]() Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 3182 ![]() |
