Browse Forums Interior Decorating Lounge 1 Dec 15, 2011 10:07 pm Hi, Just wondering if anyone has come across dining tables that use caesarstone as the top but with timber legs? I've seen plenty with metal legs but was wondering what the caesarstone/timber dining table combination will look like. Thanks Re: Caesarstone tabletop with timber legs? 4Jan 30, 2012 8:34 pm Hi Klam! I've been doing some Googling and can't seem to find anything. I wonder if you may be able to contact a custom furniture designer and see if they could mock something up for you?? Good luck! Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15908 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6141 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3278 |
