Browse Forums Interior Decorating Lounge 1 Sep 08, 2011 5:21 pm Has anyone painted their walls in dulux hot lips? Would love to see some pic's as dulux has now discontinued this colour so I can't get a sample card from bunnings. A bank is a place that will lend you money only if you can prove that you don't need it... Re: Dulux Hot Lips 2Sep 08, 2011 7:25 pm 'Hot lips' is still part of the current range (there are some changes coming but not just yet). However Bunnings do not carry the full range of the Dulux range. Sample pots should still be available, which I would suggest you try so as to get the true colour and that you are not overwhelmed by this strong colour on a larger area. Re: Dulux Hot Lips 3Sep 08, 2011 7:32 pm 4walls 'Hot lips' is still part of the current range (there are some changes coming but not just yet). However Bunnings do not carry the full range of the Dulux range. Sample pots should still be available, which I would suggest you try so as to get the true colour and that you are not overwhelmed by this strong colour on a larger area. Thanks that's great advice however we have sold our house & our 8 YO wants a red bedroom in our new house & " hot lips " was recommended to us at our colour appointment I was wanting to see some examples to give us an idea of how it looks A bank is a place that will lend you money only if you can prove that you don't need it... Hi Alex, Thanks for the reply again. I had a chat with the builder, he said he will use primer, then hydrotec which comes with colour and sealer as well. A Renderer I… 12 18065 Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12662 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13450 |
