Browse Forums Interior Decorating Lounge 1 May 16, 2011 8:51 am Need some U-shaped curtain rod holders/brackets, but those that are installed on the side (INSIDE MOUNT) - eg. inside the window reveal, or in between 2 walls, or in between a door opening. The ONLY similar product is the old style plastic thingy: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ or a slightly more modern look, but also not U-shaped: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ http://dominobrass.com.au/index.php?main_page=product_info&cPath=10_129&products_id=4991&zenid=fe24c958e1b7a40cf283121078937fa4 http://dominobrass.com.au/index.php?main_page=product_info&cPath=10_129&products_id=4989&zenid=fe24c958e1b7a40cf283121078937fa4 http://dominobrass.com.au/index.php?main_page=product_info&cPath=10_129&products_id=4990&zenid=fe24c958e1b7a40cf283121078937fa4 but I would prefer something U-shaped because once I attach both brackets to the sides, I think there is no room to manouver to install the rod into these cylinders !?! Oh yes, or the Ikea Kvartal system ... but that also can't go on the sides, only on the ceiling ... BTW, does anyone know WHY are those fittings called "Muslin rod brackets"?? Does it mean that only curtains made of muslin can be used with them?? My signature is distracting people from my wise posts ... HELP - looking for U-shaped curtain brackets to use on SIDES 2May 16, 2011 8:58 am They are called muslin as they are for only light weight fabrics. They will bend and flex almost to breaking point should you use a heavier fabric. Some things are worth waiting for. Re: HELP - looking for U-shaped curtain brackets to use on S 4May 16, 2011 8:27 pm Well, seems like Domino Brass is just about the only manufacturer of these things http://dominobrass.com.au/index.php?main_page=product_info&cPath=10_129&products_id=4991&zenid=fe24c958e1b7a40cf283121078937fa4 And, of course, you can't get it in Sydney. Unless some of you know of a similar/same product? My signature is distracting people from my wise posts ... Old Home Restoration / Renovation Cheers mate! This is exactly what I was thinking but wasn't sure if it was something I'd find on the shelf. I agree with you, fixing the brackets to the board will look… 2 3275 Building Standards; Getting It Right! When my house was built (over 7 years ago), the post brackets were done to allow for concrete porch, but they didn’t allow for the planned stone paving. I’m finally… 0 1913 That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17875 |
