Browse Forums Interior Decorating Lounge 1 Apr 12, 2011 11:57 am I HAVE ECO FRIENDLY CEMENT RENDER - I THINK ITS ACCRYLIC EXPANDABLE RENDER OVER FOAM BLOCKS. THE BUILDER NEXT DOOR GOT ROOF TILE GLUE ON MY RENDER AND SCRUBBED IT OFF WITH A PLASTIC BRUSH AND WATER AND THE RENDER SIMPLY DISOLVED! DOES ANYONE KNOW MUCH ABOUT THIS ACRYLIC RENDER? IS IT DURABLE AND HOW HARD COULD YOU KNOCK IT WITHOUT IT DENTING. KELLY Re: ACCRYLIC RENDER ON FOAM BLOCKS 2Apr 13, 2011 8:37 pm Kelly, this is a product I am unfamiliar with. I haven’t come in contact with it so far, so I can’t help you. You might want to post this up in the building forum and see if someone up there can help you. Good luck Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 4143 There is nothing in the various codes and standards that puts this requirement on the builder to do. I think that is what you are asking. Don't waste time trying to get… 5 2401 Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 13762 |
