Browse Forums Interior Decorating Lounge 1 Jan 06, 2011 10:12 pm hi, I'm thinking whether to put a set of frames (arranged in a row ) on the side of the kitchen wall. I always walk pass that wall to the master room and now it's too bare. The wall is 600mm long, and the light switch is a bit off centred, to the left side. It's at roughly 1.1m from floor. the frames are for 4x6' photos ones, so the size is a little bit larger than that i guess the bottom frame may be a bit close to the switch ( they will be centred on the wall, so the last one will be on the right of the switch). The switch plate is the standard cream one. I'm unsure if the frames will not look great with the switch. ( distracted?? ) sorry that i don't have a pic of the frame thanks for your opinion. Re: Should I put frames on that wall? 2Jan 06, 2011 10:29 pm Do you have a picture of the wall? Is this the wall opposite the wall where you placed the hall table? Have you put anything above the hall table? I am a bit hesitant to put too much on walls facing each other in a hallway, as it closes the space in and make it feel very busy. Re: Should I put frames on that wall? 3Jan 07, 2011 5:51 am I’d like to see a photo as well, need to see the space you are walking through and the surrounding area. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17895 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8324 |
