Browse Forums Interior Decorating Lounge 1 Aug 29, 2010 1:00 am Hey all I thought I would help out a few more bits of info on paint I used to manage an independent paint shop that stocked most major brands, a major paint company, and on some pretty awesome film and TV sets as well so I know a little bit Now every paint company has levels of quality from best to worst Ultra premium Premium Trade premium Trade Budget The difference in the quality comes down to base materials, the more expensive the more high tech and equals better covering, stain resistant, smoother finish, easier to apply Always go for an Ultra premium product it will make you look like a pro, highest stain resistance, best technology I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Paint 101: BASES 2Aug 29, 2010 1:00 am now we all know paint comes in Base WHITE but there are other bases to achieve darker and vibrant colours White Accent Neutral Coloured(pre-tinted base) However to make it difficult Bristol has White A B C Coloured the further you stray away from a WHITE base the less covering power you have (except for pretinted bases) Bristol A base is pretinted with Raw Amber and help reduce tint use to achieve off white/neutrals but needs tint to help dry properly Neutral base is almost clear and uses HUGE amounts of tint to achieve vibrant colours but it means more coats and sometimes a tinted undercoat to achieve coverage So when you see a Vibrant colour and want it half strength sometimes it just cant be done due to the base (especially neutral considering it is virtually clear) I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Paint 101:TINTING & COLOUR MATCHING 3Aug 29, 2010 1:27 am Tinting is what gives the paint its colour but some colours can have multiple combinations of tinter colours to achieve certain colours Each paint company will have its own tinter system most use manual system on a rotating platform that require the tinter to look up the correct formula in a book or screen and then make up the mix Solver Dulux Wattyl Taubmans Some paint companies now employ fully automated tinting machines to take the human element out of it Bristol Taubmans Dulux However all the machines are only as good as the upkeep and calibration A daily clean at minimum, 6 mthly calibration to keep the machines in tip top shape Along with automated tinting machines there is also the Spectrophotometer or colour matching machine. Personally I am not a fan of the Colour matcher, it will only work at its best if the sample is flat, clean, solid, and needs to be around 2 cm sq rarely does the sample needing to be matched, tick all the boxes and many paint store staff rely on it, instead of developing the skills to match by eye from scratch or with fandeck (how do you think you get to work on Film and Tv??) I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: Paint 101 4Aug 29, 2010 10:21 am interesting... thanks Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Paint 101:Sheen levels 5Sep 06, 2010 12:50 am So I hoped I helped a little bit Bagheera here are my tips regarding what sheen level and where Ceilings - Ceiling white(Ultra flat) to all ceiling areas except bathroom and laundry even with fly poo it can be touched up with minimal sheen difference due to the ultra flat paint Bathrooms and laundry - Satin/Semi gloss (Walls and Ceiling) better moisture resistance and can have a higher mould resistance ( you can get a Low sheen product too but coating performance is not as good IMO) Walls - Low sheen superior hiding of wall imperfections and good stain resistance Now just be aware there are different kinds if grime and the different brands tackle certain types One major brand has Superior water based stain resistance (wine, etc) while another has Superior Oil based stain resistance( finger marks etc) Most common stains are oil based so it made my choice easy (PM me for the products if you want to know) both can handle the others stain resistance but to a lesser degree Interior Trims, windows, and Doors - Satin/Semi-gloss or High Gloss ENAMEL Thats right OIL based enamel wash it up with TURPS Hard wearing, and smooth and does not flex like a Water based Gloss Sure clean up is a pain in the bum but the finish is superior Water based finishes are essentially plastics and when the temp increases they become pliable and can stick to surfaces They are convienent but not a hard wearing product I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7170 Thank you. That is really helpful. Once we get the place done and passed for OC we can upgrade in the future once we get back on our feet and not paying mortgage and rent. 4 5745 DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 8914 |
