Browse Forums Interior Decorating Lounge Re: Advice on Skinny Entrys needed 41Aug 05, 2010 7:40 pm I had a skinny entry in the first place I built. A big mirror is all I would put on the wall because if theres anything else in there it makes is feel even smaller than it actually is. Also make sure its painted light and the lighting is great as it will make all the difference. In cottage homes always make sure you have slimline furniture. A sofa with a chaise is makes a great statement however uses much less room than 2 sofas. A low ****** TV unit and a average sized flat screen wall mounted TV can make a room feel much larger than it actually is. Buy the right furniture and get the right look and you will make more $$ when it comes time to sell. If you dont have high ceilings install downlights. Big hanging lights in smaller rooms makes the ceiling feel like its falling in on you. Minimalist wins when you dont have a large floor space and make mirrors, glass furniture and light your friend. Space is often an illusion. Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6842 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 6980 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15102 |
