Browse Forums Interior Decorating Lounge Re: Colour scheme to work with brown Kalahari slate 21Oct 03, 2009 7:31 pm HI Michelle, if we were to use your dulux "sea crystal" (or similar) could you please recommend a colour for the walls? The wall colour would need to flow through the rest of the house. I would prefer not to have "pure white' skirtings, but would like a light neutral colour, that works with both the slate floor and the blue. THANKS so much I would probably render it and then paint it as per your other advice, or gyrpock over the top. 1 3339 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 398 just pull up the slate. If you go over the top, your tiles would not have an even surface to be glued to. Im no tiler, but i can imagine a couple of things being an issue… 1 342 |
