Front entry wall..
As you know Ive been looking for ways to spruce up the front entry.. and I think Ill go for tiles.
Have a look at photo number 7 and 8 of the Imperial by Mcon - http://www.metricon.com.au/victoria/hom ... fault.aspx (replace *** with Mcon).
Do you know what this tile is??
I was guessing it would be Luxe Anthracite from Beaumont.. http://shopping.tile.com.au/TilesBathro ... 0x300.aspx
This one is different to the tile used in M's Imperial.. http://shopping.tile.com.au/TilesBathro ... 8x600.aspx but its SO expensive!!!
What do you think will look better.. the first or second tile?
I want to achieve the same affect as the Imperial.. our house colours are very similar to that display - white painting and white tiles. Look in my photos thread.
Or should I go back to the drawing board and do stacked stone??
Thanks!!!!!
I prefer the tile over the stacked stone. The tile will give a classy sleek sophisticated look.
If you were looking to go with one of those two tiles, my vote goes to the Luxe Anthracite
Judie
I also think that a tile size 600 x 300 or along those proportions would look better than a square tile as a feature tile. Don't know why ... just my opinion.
Good Luck ... you will know exactly what you like and soon as you see it ... I think you need to check out a few tile shops and see what jumps out at you.
6
Black on light wood does look good. Not sure if it will be as long lasting as a steel finish?
10/03/2024
I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an…
7/03/2024
4
Thank you again Simeon.. I will call my certifier for that. Have a good day
