Browse Forums Interior Decorating Lounge Re: Colour Advice 2Sep 05, 2009 12:07 pm progress viewtopic.php?f=31&t=20401 sculptures viewtopic.php?f=36&t=26607 pole trouble viewtopic.php?f=3&t=25988 Re: Colour Advice 3Sep 07, 2009 5:06 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Colour Advice 4Sep 07, 2009 7:42 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Colour Advice 5Sep 07, 2009 7:46 pm Michelle [Will also be installing under stair storage (with doors) and built in entertainment unit which rep has said would look good if in satin finish poly in same colour as main wall colour - will this look OK? . This will help the built-in unit disappear/blend with your walls, is this what you want? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15711 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13817 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6895 |
